Onda M3 Combo PC LGA1150 Support Celeron G Pentium G Core WIFI Gigabit LAN Bluetooth4.0 SATA HDMI VGA DYI
    *Suitable for i3 Or i5 Intel CPU, up to *256 mSata + *2 TB HDD up to *8 GB Ram *(yet to be 100% confirmed)
    BYO Hardware and Software for this baby, Ram, CPU, Software
    A DIY mini PC, Onda M3 allows you to install any software at will, hence you are able to design your own special PC.
    • Frosted aluminum body, delicate and light
    • Supports LGA1150 interface, Celeron G, Pentium G, Core processors
    • Note: Onda M3 Mini is a bare PC, you will need to BYO software & hardware and install
    A good idea to make a box that allows the user to choose the processor.
      Hi!
      What would you recommend as a value-for-money combo of processor, msata and ram?
      I see this barebones device is sold arnd USD200, budget of another 100-200 for the rest.
      Thanks.
        Originally posted by jacknathan89 View Post
        Hi!
        Thanks.
        What uses would you have for your ideal setup?
