MXIII-G with S812 chipset and running Android 5.1
But when I hook it up via the AV output, the picture on the screen oscillates rapidly from top to bottom, is grainy, is black and white, basically looks very broken.
The HDMI works perfectly fine.
Is this a hardware or software problem?
Edit: Further investigation shows that the box may be outputting PAL format, while my TV is NTSC. I searched through both the OS options and the deeper Android options but found no options for switching between PAL and NTSC. the only option I found that was remotely related was HDMI CEC.
