Ricomagic rom 63301224
It's not a beta but its not great. I can't seem to turn off touch sounds so I'll be hearing click click click in my sleep. Probably works best with xbmc launcher and disable nav sounds. 4GB of app space, so not good on the V5 or 903V, no space for addons.Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
Ok tested it. Unlike the above post. Sound works with settings you can turn off that click if you wish (turn down the volume for it in sound settings)
Not rooted. The kodi installed is with addons and kinda buggy so I removed installed beta 4 will play with this tonight.
YouTube works google plus work. Chrome works play store updates fine. Gets faster after a boot or two. Sees lots working bluetooth network all running fast and we'll.
Rooting lollipop is a bitch and seem like unless the root is done for specific device it always break something else in the build. So hopefully neomode or files can help us get proper root on this device. All in this looks like a good updated lollipop stock rom.
Power off still a fudge pack.
Neo mode also posted newer Peramiter file that is full use of memory if that's your preference.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
There are currently 2787 users online. 1 members and 2786 guests.
