Does anybody have the original Beelink firmware (with 2G/16G and 6335 WIFI) ? The version found on the internet : update_R89_111k4110_beelink / update_R89_111k4110_1219
( by the way what is the difference between them), are not exactly the ones that came with the device. I could not make a backup of it, and between tries I was "forced to put another firmware in order to unbrick the device. I tried all the firmware available, (OHC, WASSER, Finless), but none of them could make playing video fine through kodi supporting also.of DTS and AC3 . With original ROM I did not encounter any issue.
