I've spent the last ten or so years running xbmc off an old xbox and it's never let me down, apart from shoddy MP4 and MKV support.. I decided to upgrade, and went for the OTT M8 box as it had good reviews. The first week it was a dream, but lately it's just a continual lag.
All I'm after is the ability to watch stuff through Genesis in Kodi without having to drop down to MQ streams, and the ability to read from USB HDD.
I figured it was just a case of upgrading the firmware, but after spending an hour plus online, there seems to be pretty high odds of bricking the box.
So I'm asking for any helpful advice out there... In trying to do my part to be helpful, I've attached a load of pics of the PCB in hope's someone can properly identify it, multiple pics in an attempt to nail as much info on the chips as possible.
Info I can see on the board & chips:
M8 V8_6 - 20150820
SKhynix - H27UCG8T2ETR - BC - 438A
H1102NL - SUR 1530HS
AP6330 - T30F8002 - 1534
The firmware according to the screen is K200.
Any and all help would be massively appreciated!!
Cheers,
Mook.
Edit: I should mention I'm using a wired connection, running over Virgin Media... I get good speeds on laptops, tablets, phones and ps3.
