Lollipop s82 plus
Originally posted by Xizor View PostHave you tried Tronsmart MXIII Plus 5.1 firmware? Seems very stable on my MXIII-G.
I upgraded to the newest Kitkat rom for mine and it's worse than it was, video playback is worse and the playstore keeps crashing.
Will certainly work with the MXIII Plus.
Don't know about the Beelink, but it's worth a try. It is a S812 device and they are all quite similar. Can't be sure though.
Quite difficult to brick these boxes as long as you use suitable firmware and the correct method for flashing. I would reccomend the Amlogic burning tool. Has worked every time for me. Had a few failures using the microSD card way. The burning tool overwrites any bad firmware on the device.
Good luck!
PS.This any good to you? https://www.youtube.com/watch?v=KPpJMgM1d1Y
Thanks Xizor. On looking about, it seems that I have a diff wifi chip. I had tried the sd card method before but never worked for me. As you say the burning tool was fine.
So worst case scenario is that I could try it and if it doesn't work, just flash back? Was looking at the Tronfy MXIV, which seems to be more compatible.
I tried quite a lot ( Beelink and Tronsmart )and they were all non functional as first for Ethernet ( our is 100 and last ones are all 1000 ), Secondly they were rebooting every 3 minutes at the most. Our wifi is AP6335 and most of others have AP6330 ( if they are original ). Best bet are 115k4 all in one Firmwares ( Abdul PT here on Freaktab) . Also found a similar one on Mediabox, from Mediaman ( is part of the last group of STAR WARS ROMS ). This is the last and upgraded ( but here, too, Bluetooth is not working, we wait for Mediaman magic ).
Let me know your findings, mine now is at a friend I had to make a gift to.
Originally posted by vn800art View PostI tried quite a lot ( Beelink and Tronsmart )and they were all non functional as first for Ethernet ( our is 100 and last ones are all 1000 ), Secondly they were rebooting every 3 minutes at the most. Our wifi is AP6335 and most of others have AP6330 ( if they are original ). Best bet are 115k4 all in one Firmwares. Also found a similar one on Mediabox, from Mediaman ( is part of the last group of STAR WARS ROMS ). This is the last and upgraded ( but here, too, Bluetooth is not working, we wait for Mediaman magic ).
Thanks again mate
Originally posted by neomode View PostDon´t blame the Sellers.
It is Amlogic itself they don´t release a SDK for it.
Neomode
There are currently 2603 users online. 4 members and 2599 guests.
