But as long as temperature seems to raise to over 90 degrees Celsius, it automatically goes back to min. 768mhz and max 768mhz too. Governor stays the same though.
Then the temperature goes below 75 degrees, but emulators and other apps suffer from performance issues.
I've tried to use no-frills cpu control that has an option to forbid speed changes but it doesn't seem to work.
I'm trying to isolate the problem and confirm if it's an overheating problem, a very conservative processor speed/temperature policy or a firmware bug.
I will try to put a larger heatsink to the SOC and try if this alleviates the issues.
But, anyone does know if there's any way I can change the CPU throttling policy? to put higher temperatures for the CPU to start to slow down (and try not to fry it
Motherboard reference: KCA-008 1.2
NAND Chip: Hynix H27UCG8T2ETR BC
Shop link: http://www.aliexpress.com/item/2015-...311040550.html
Working stock flashable firmware:
http://www.mediafire.com/download/2s...t_firmware.img
