Will you let me know if you found something?
MXQ 4K RK3229 Smart TV Box Android 4.4 1G/8G H.264/H.265 10Bit WIFI LAN KODI 16.0 HDMI DLNA AirPlay Miracast
Originally posted by piggy99 View PostThanks.
The recovery button is indeed in the AV hole. Unfortunately, I was not able to upgrade via windows. Device not recognized.
Hello I want to buy the box. However, I have a few questions.
1.) What screen resolution has the system?
2.) Most Android Boxes have only 720p and you can not adjust with Kodi.
3.) Run kodi Smooth, supported hardware acceleration in Kodi?
Or should I use for H265 and 4K always an external player?
Thank you geekbuying.
Found the recovery button.
However could not find get the PC to recognised the box using version 1.8 and the drivers provided and also tried the latest drivers I find on the net.
Still trying to update...Can you provide the drivers that the box will recognise?
Originally posted by GeekBuying_Rep View Post
In av and spdif which has reset button, you can press anyone
Hi.. brand new here and not techie at all.. really impressed reading some of the forum, and the tech knowledge around here.. !!
I have this same box... been fighting with getting smooth video since i got it.
I now have smooth video, however had to switch off audio passthrough in kodi to make it work... therefore i now have good video. but can't listen in dolby or DTS..
are any of the fixes here related to this problem..??
I'd love to get my good audio back while maintaining the decent video.
thanks a lot.. !!!
Michael
Originally posted by miguanos View PostHi.. brand new here and not techie at all.. really impressed reading some of the forum, and the tech knowledge around here.. !!
thanks a lot.. !!!
Michael
There are currently 2346 users online. 0 members and 2346 guests.
