not sure what my rk3066 tv dongle is
hi all im new to freaktab i come from another development site because there is not much development for these devices there. i bought my dongle off **** from a company in china. it is an r-box rk3066 either an mk802 llls or a mk808 there is nothing on the outer of the box im rooted so i checked the build prop and it says nothing about the model i want to flash CWM but cant untill i find out my model is there an app that anyone knows about that could tell me i have tried antutu but it just reads it as rk30sdk im stuck.Last edited by gavster26; 30 May 2013, 22:11.My Works @XDA:
AVD Rom Xperia J The Way Stock Should Be
Pre Root Xperia J 4.12
Deodex Xperia L
Deodex Xperia Z kitkat
Stock Xperia Icon's For CM11
Tags: None
maybe this app will help you sort your issue ????
although it can only read what is in build.prop so it may not be what you seek
R Box hmm... - new one to me but I see the mk809II has a rbox bootscreen logo according to this poster http://www.armtvtech.com/armtvtechfo...&t=1769#p10934
it is possible and most likely a clone if it does not have any info on the case or on the original packaging and these can sometimes be tricky devices
you might want to compare the pics of the various devices to yours for most likely it has a shell same as what device it is cloned of but firmware and cwm might not work on it ...here are a few that you can compare just google for images of the devices
these are dual-core devices
mk808 - mk809 - mk802III - hm908 - measyU2a -
ipazzport - cx803II - ug802 - justopk9 - egreat h6 - miniXg4 neo - t001 - pc803 - imito mx1 - ug008
that's a few to compare and I am sure I am missing some - Good Luck!!!Have a Great Day!!!!
R-box
Originally posted by twjordo View Postmaybe this app will help you sort your issue ????
Originally posted by benster1 View PostThe alternate rom for 809II clone has a r box bootlogo.
pic here of mk809IIHave a Great Day!!!!
Its defiantly not not an mk809 the advert said an mk802 llls & an mk808 it is defanantly a clone i just dont know which. The **** seller is not answering my messages so i don't Know what to doWould pics of it help any of you identify it.
My Works @XDA:
Deodex Xperia L
Originally posted by neomode View PostYes open the Device and send Pictures of both sides. And make a close Photo of the Wifi Chip. This Chip is near were the Antenna is connected.
Thx
Neomode Freaktab.com Developerthen use this wifi chipset guide to locate your chipset and you should know what device you have
Thankyou
Thankyou all i have an mk808now i am in trouble i tried flashing an xperia z walkman nod and now it wont streem video from any app i have tried manualy deleting all the files flashed but still no good. i am trying to reflash stock with rk batch tool but my mk808 clone does not have the button through a small hole just a button next to the mini usb cable and it does not put it in flash mode. i have been trying to build a CWM flashable zip to flash it but no img tools can extract the update img files im at a loss. does anyone have system dump for this device please.
My Works @XDA:
Deodex Xperia L
There are currently 1621 users online. 0 members and 1621 guests.
