Anyway, from what I've read, the M9S was created so that the 3G version could be OEM'd in a partnership with a Chinese telco. Whether that is true or not, I don't know. What I do know is that so far no one has found or released anything past 4.4.2 for this device.
What I'm wondering is if the P7 hardware would be close enough so that the P7 lollipop ROM would work for the M9S.
The specs are nearly identical. There are only 2 differences on the spec sheets and they are screen size and battery capacity. The P7 having a 9.4" screen vs the M9S having a 10.1" screen. Also, the P7 battery at 6400mah vs the M9S battery at 7600mah.
What I don't know is if there are fundamental differences between the display drivers, if they use the same PMU, if the RAM is of a similar type, etc. Could someone with a little more knowledge of both devices help me out here with an opinion?
If not the P7, then does anyone know of a device which is the OEM equivalent of an M9S which may have better support for newer ROMs? I'm interested in Lollipop, possibly lightbiz OS, ChromeOS, or other Linux based fw.
Thanks and cheers!
-SB
