LIVA X² Barebone is Intel® Braswell SoC, Celeron® Processor N3050 small barebones of equipped with palm-sized mounted. Intel® HD 4K high-resolution output and the next-generation video compression technology HEVC (H265) by Graphics are supported in hardware playback support. Completely silent operation by fanless design. Low voltage DDR3L 4GB memory, wired connection of Gigabit LAN, capable of high-speed wireless communication Wi-Fi 802.11ac, it is equipped with a Bluetooth 4.0. Equipped with a video output terminal HDMI and D-sub, corresponding to the dual monitor by simultaneous output. By simply put the OS, such as Windows 10 / 8.1 / 7 it is possible to build a desktop PC.with eMMC 64GB and storage expansion for M.2 slot "LIVAX2-4 / 64", and line up the two models of equipped with Intel M.2 SSD 120GB "LIVAX2-4 / 120 (M2)".
No crippling Non expandable Emmc.
LIVA X² Barebone
Model number LIVAX2-4 / 64 LIVAX2-4 / 120 (M2)
JAN 4580137829317 4580137829324
OS -
Processor Processor Intel® Celeron® Processor N3050
Cores / Threads twenty two
Base operating frequency 1.6 GHz
Burst frequency 2.16 GHz
L2 cache 2 MB
Graphics Graphics Intel® HD Graphics
Base operating frequency 320 MHz
Burst frequency 600 MHz
Execution unit Twelve
DirectX Correspondence
OpenGL Correspondence
QSV Correspondence
HEVC (H265) Hardware playback support
Memory standard DDR3L
capacity 4GB
Storage eMMC 64GB -
M.2 - Intel 120GB
Expansion slot 1 × M.2 2280/2242 (SATA) Because of the pre-installed, there is no M.2 2280/2242 (SATA) empty slot for expansion.
Video output Output terminal 1 × HDMI 1.4a
1 × D-sub
Maximum resolution HDMI: 3840 × 2160 @ 30 Hz
D-sub: 2056 × 1536 @ 60 Hz
Wired LAN Realtek RTL8111H Gigabit LAN (10BASE-T / 100BASE-TX / 1000BASE-T)
Wireless LAN (NGEF Key E Type) Wi-Fi 802.11ac (433Mbps)
Bluetooth Bluetooth 4.0
audio Realtek ALC283 2ch
Interface 1 × HDMI
1 × D-sub
1 × Gigabit LAN port
2 × USB 3.0
1 × USB 3.0 (EZ Charger)
1 × audio output and Mic 3.5mm combo jack of
1 × power supply DC port
Cooling system Fanless heat sink
Corresponding temperature and humidity Operating temperature / Operating humidity 0 ~ 40 ℃ / 20% -80% RH
Non-operating temperature / Non-operating humidity -20 ~ 60 ℃ / not over 90% RH
AC adapter Input: AC100-240V
Output: DC12V / 3A
power consumption Maximum power consumption About 20.96W
Standby power consumption About 3.75W
Supported OS Windows 10 64-bit (UEFI)
Windows 8.1 64-Bit (UEFI)
(available only if you have the installation drive the M.2) Windows 7 64-bit
Linux (M.2 only if you have the installation drive available)
VESA Correspondence
security 1 year
accessories 1 × Quick Installation Guide
1 × VESA mount
1 × (for VESA mount) Screw set
1 × M.2 fixing screw
1 × AC adapter
1 × AC plug shape conversion connector -A type (to 100V outlet in Southeast Asia, such as Japan corresponding conversion connector)
1 × AC plug shape conversion connector -C type (mainly European conversion connector corresponding to the 200V outlet of the region)
to the 200V outlet, such as a 1 × AC plug shape conversion connector -BF type (part of Southeast Asia corresponding conversion connector)
1 × driver DVD (for Windows 10)
Windows 8.1 / 7 for driver http://www.ecs.com.tw/ECSWebSite/Pro...D=1626&LanID=0
For installing Windows 7 To install the Windows 7 requires a built-in pre-USB3.0 driver on the installation disk. Please take advantage because I was available: the patch tool for automatically embedded.
Patch tool (click the download will begin)
Body size 156 x 83 x 51 mm
Body weight About 560g
Package Size 258 x 135 x 64 mm
Package weight About 1100g
Notes ※ LIVAX2-4 / 120 (M2) is eMMC not mounted, Intel M.2 SSD 120GB pre-installed for, there is no M.2 2280/2242 (SATA) empty slot for expansion. ※ M.2 2280/2242 SSD replacement and expansion of the decomposition of the body entails. SSD exchange also the body of the decomposition time of corruption and other problems associated with the expansion will void the warranty.
Source :Links.co.jp
