Thanks for any help
Root Kit M8S+ OS 5.1.1
Reset box to factory settings by holding in toothpick while plugging in power,
reboot
Put a twrp2870 img on a SD card rename it recovery.img
Put SuperSU-v246.zip on USB thumb drive.
Attach USB mouse.
Insert usb and sd card using toothpick method above... hold 'til twrp screen
select install
select the usb drive and choose the SuperSU.zip file
select reboot SuperSU should be in the apps drawer.
I just did this yesterday and my M8S+ is new from geekbuying via amazon, if its a clone or not who knows I didn't open it to check,
**Install apps after rooting or permissions get all twisted.Last edited by pepe7; 31 March 2016, 23:59.
There are currently 2316 users online. 2 members and 2314 guests.
