So some people asked me if I could make the 2015 stock ROM downgrade from the new 2016 ROM.
Currently the 2015 stock ROM will fail via SD card method when trying to downgrade from the 2016 ROM.
This is due to a version check in the scripts.
I have removed that check and now you can downgrade back to the 2015 ROM.
Nothing else was changed! This is the stock 2015 ROM for the Telos.
This is for the Telos only!
Instructions:
Download this file 2015_telos_downgrade.zip
Unzip it and put these 2 files on a fresh formatted SD card.
2015.zip
recovery.img
Note, I do not have the keys yet to be able to sign the ZIP files for the stock recovery.
Thus it is important you have this recovery.img on the SDcard.
When you go to do the update if you get a error then the box did not boot the recovery from SDcard.
Make sure you used a fresh formatted SDcard and that you copied the files correctly.
Go to "My Apps" and run "Update & Backup".
Click on "Local Update" and click on "Select".
It should find 2015.zip on your SDcard.
Select that and proceed.
The S95 will reboot and install the update and your done!
Enjoy!
ROM -> S95 Telos ROM 2015 downgrade (511 megs)
