ROOFULL Open offical Amazon online store for USA, buy MRX 2+16 1000M Ethernet TV Box: http://goo.gl/OiNtrg
We have been waiting for long long time, yes, we take about 3 month to create this TV box: MRX, these two days, we get this TV box and prepare this review blog. This MRX TV box use the Amlogic S905 quad core chip with penta core GPU, this is the newest chip suitable for Android tv box from Amlogic company, you can check the more informations about this processor.
We have prepare the MRX TV Box review, in this video, you can find the unboxing, appearance, UI, Antutu Benchmark test, H.264 and H.265 4K video test, Kodi and Addons:
Following is the quick view of this MRX Android TV box:
Model:MRX
System: Android 5.1 Lollipop OS
Chip:Amlogic S905 (64-bit) Quad Core
RAM: 2GB DDRIII RAM
Flash: 8GB eMMC
Video: UHD 4K @60fps
WiFi:2.4G + 5.8GHz
Bluetooth:4.0
HDMI:2.0
LAN:1000M
This Amlogic S905 looks like a substitute for the old Amlogic S805, but the performance is much larger than S805, so in our opinion, AML S905 is a complete new product, for example, S805 only support 1080P video, S905 support H.264/H.265 all 4K video. As well as their official propaganda, S905 is the 64-bit processor, to be honest, most even all processors will be 64-bit processor, basically, we have said goodbye to the old 32-bit chip.
Our new MRX TV box use the 100/1000M LAN, support the 2.4GHz + 5.8GHz dual band WiFi, meet all current network environment. By the way, about the 2.4GHz wifi and 5.8GHz wifi, some users may do not know it, what is the 2.4G wifi and 5.8G wifi, usually, we all use the 2.4G wifi some years ago, because there is no 5.8G wifi, however currently, our network speed have been faster and faster, and there are more and more smart device need the wifi, which cause the network congestion, so the 5.8GHz is like a new highway with few equipments connecting in, normally, 5.8G wifi is much faster than 2.4G wifi. And how to use 5.8G wifi? You just need to prepare a router that support 5.8G wifi and your devices support 5.8G wifi, just find the 5.8G wifi in your devices and connect it, it’s ok. Our MRX S905 TV Box support 5.8G wifi, so if you have the 5.8G network environment, you can use this TV box to play up to 4K online video.
About the 4K video, at the beginning of the 4K video development, most 4K videos are H.264 compressed format, during the development, more and more 4K video use the H.265/HEVC compressed format, some Android TV box can not play it, such as Amlogic S802 Androdi TV box.
Mrx Android TV Box also support Bluetooth 4.0, physical button to turn on/off by one click, OTG port, 2*USB port, HDMI 2.0,SPDIF, AV, TF Card and power supply specifications for different countries...
MRX use the 9K gold plated HDMI 2.0 port, in order to improve the transmission stability.
The same as i68, this MRX also use the AP6330 wifi chip.
Above are some information about MRX Amlogic S905 Android TV Box, about more update about this box, we will release blog here.
Article Source: http://www.roofull.com/news/mrx-amlo...tv-box-review/
