I'm writting you because I bought a Minix Neo X8-H on Aliexpress in 25th of June, 2014 and one month ago it stopped working and now it doesn't start when I power on.
I've tried to flash official firmware 007 (and all the other official versions) using USB BURNIGN TOOL but it fails at 4% while formatting. I have connected Minix to PC and when I did it before to upgrade firmware, it worked without any problem but at this moment it doesn't.
It's impossible to flash firmware with USB Burning Tool, so the device is unusable.
You can see an error image here:
And you can see the error file here:
[16:00:00 007][Global][Inf]-------->[Port0]NoDeviceConnected [16:00:00 007][Global][Inf]-------->[Port1]NoDeviceConnected [16:00:00 007][Global][Inf]--Host: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A [16:00:00 007][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_293a&subsys_3603103c&rev_03#3&21436425&0&ef#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [16:00:00 007][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&28e6ef17&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [16:00:00 080][Global][Inf]-------->[Port0]NoDeviceConnected [16:00:00 080][Global][Inf]-------->[Port1]NoDeviceConnected [16:00:00 080][Global][Inf]-------->[Port2]NoDeviceConnected [16:00:00 081][Global][Inf]-------->[Port3]Other device [16:00:00 081][Global][Inf]-------->[Port4]NoDeviceConnected [16:00:00 081][Global][Inf]-------->[Port5]NoDeviceConnected [16:00:00 081][Global][Inf]-------->[Port6]NoDeviceConnected [16:00:00 081][Global][Inf]-------->[Port7]NoDeviceConnected [16:00:00 082][Global][Inf]--Host: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C [16:00:00 082][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_293c&subsys_3603103c&rev_03#3&21436425&0&d7#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [16:00:00 082][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&30bdaea4&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [16:00:00 082][Global][Inf]-------->[Port0]NoDeviceConnected [16:00:00 082][Global][Inf]-------->[Port1]NoDeviceConnected [16:00:00 082][Global][Inf]-------->[Port2]NoDeviceConnected [16:00:00 083][Global][Inf]-------->[Port3]\\?\usb#vid_1b8e&pid_c003#5&33ae2767&1&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} [16:00:00 084][Global][Inf]--Host: Intel(R) ICH9 Family USB Universal Host Controller - 2937 [16:00:00 084][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_2937&subsys_3603103c&rev_03#3&21436425&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [16:00:00 084][Global][Inf]---->Roothub:USB#ROOT_HUB#4&6a45db3&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [16:00:00 110][Global][Inf]-------->[Port0]NoDeviceConnected [16:00:00 110][Global][Inf]-------->[Port1]NoDeviceConnected [16:00:00 111][Global][Inf]--Host: Intel(R) ICH9 Family USB Universal Host Controller - 2938 [16:00:00 111][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_2938&subsys_3603103c&rev_03#3&21436425&0&d1#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [16:00:00 111][Global][Inf]---->Roothub:USB#ROOT_HUB#4&1c13a626&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [16:00:00 137][Global][Inf]-------->[Port0]NoDeviceConnected [16:00:00 137][Global][Inf]-------->[Port1]NoDeviceConnected [16:00:00 138][Global][Inf]--Host: Intel(R) ICH9 Family USB Universal Host Controller - 2934 [16:00:00 138][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_2934&subsys_3603103c&rev_03#3&21436425&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [16:00:00 138][Global][Inf]---->Roothub:USB#ROOT_HUB#4&33b02ea4&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [16:00:00 138][Global][Inf]-------->[Port0]Other device [16:00:00 138][Global][Inf]-------->[Port1]NoDeviceConnected [16:00:00 139][Global][Inf]--Host: Intel(R) ICH9 Family USB Universal Host Controller - 2935 [16:00:00 139][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_2935&subsys_3603103c&rev_03#3&21436425&0&e9#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [16:00:00 140][Global][Inf]---->Roothub:USB#ROOT_HUB#4&1e40e631&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [16:00:00 166][Global][Inf]-------->[Port0]NoDeviceConnected [16:00:00 166][Global][Inf]-------->[Port1]NoDeviceConnected [16:00:00 167][Global][Inf]--Host: Controladora de host USB genérico compatible con xHCI [16:00:00 167][Global][Inf]--DevPath:\\?\pci#ven_1b21&dev_1042&subsys_2104174c&rev_00#4&9836b4b&0&00e5#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [16:00:00 167][Global][Inf]---->Roothub:USB#ROOT_HUB30#5&3d9dc78&1&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [16:00:00 167][Global][Inf]-------->[Port0]NoDeviceConnected [16:00:00 167][Global][Inf]-------->[Port1]NoDeviceConnected [16:00:00 167][Global][Inf]-------->[Port2]NoDeviceConnected [16:00:00 167][Global][Inf]-------->[Port3]NoDeviceConnected [16:00:00 167][Global][Inf]--Scan USB host controller complete [16:00:00 168][Global][Inf]--Update data center with HubMap [16:00:00 168][Global][Inf]--Update hub4 device data [16:00:00 168][Global][Inf]--Update HUB4-1 [16:00:00 168][HUB4-1][Inf]--Update device path [16:00:00 168][Global][Inf]--Update HUB4-2 [16:00:00 168][HUB4-2][Inf]--Update device path [16:00:00 168][Global][Inf]--Update HUB4-3 [16:00:00 168][HUB4-3][Inf]--Update device path [16:00:00 168][Global][Inf]--Update HUB4-4 \\?\usb#vid_1b8e&pid_c003#5&33ae2767&1&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} [16:00:00 168][HUB4-4][Inf]--Update device path [16:00:00 173][HUB4-4][Inf]--Device is connected [16:00:00 173][HUB4-4][Inf]--Close device handle 0x00000830 [16:00:00 224][HUB4-4][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&33ae2767&1&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x00000830 [16:00:05 288][HUB4-4][Inf]--0-7-0-16 [16:00:05 288][HUB4-4][Inf]--CheckFileRunState succeed [16:00:05 288][HUB4-4][Inf]-- low_power [16:00:05 288][HUB4-4][Inf]--Send command success [16:00:05 288][HUB4-4][Inf]--Read command status success [16:00:05 288][HUB4-4][Inf]-------------ERASE FLASH----------- [16:00:05 288][HUB4-4][Inf]--disk_initial 1 [16:00:05 288][HUB4-4][Inf]--Send command success [16:00:15 554][HUB4-4][Err]--failed:[16:00:15 554][HUB4-4][Err]--Check command return failed [16:00:15 569][HUB4-4][Err]--[0x30201004]UBOOT/Disk initialize/Send command/Error result [16:00:15 569][HUB4-4][Inf]--Close device handle 0x00000830
I'm afraid my device is dead. In my opinion the eMMC have an issue and I don't know how to solve it.
Here you can see what I obtain when I try to install an official firmware using recovery mode:
As you can see, eMMC is not mounted, so it's impossible to flash any firmware.
Does anybody know how to mount eMMC?
Thanks.
