Help me understand the memory partition
I am running the Finless 1.7c rom on my mk808. When you look at apps in the settings menu it shows internal memory and SDcard. However the SDcard is not actually an SDcard, but rather the other side of the partition. How can I actually put apps on the SDcard and not the other side of the partition that it refers to as the SDcard? How difficult is it to move the partition to allow for something like 5 or 6 gigs for apps?Tags: None
Re: Help me understand the memory partition
Originally posted by livinlife View PostI am running the Finless 1.7c rom on my mk808. When you look at apps in the settings menu it shows internal memory and SDcard. However the SDcard is not actually an SDcard, but rather the other side of the partition. How can I actually put apps on the SDcard and not the other side of the partition that it refers to as the SDcard? How difficult is it to move the partition to allow for something like 5 or 6 gigs for apps?
Bob gives diferent parameters files in his rom, so you only need to choose a parameter file with more space for apps, i think that 4 Gb parameter file is provided with his roms.
There are currently 2021 users online. 0 members and 2021 guests.
