New Android box needed with special REQ´s
    Hi all,
    I think I need some help, buying a new Android box because of sound lags.
    Background:
    My Andoer CX-998 box is mounted in my glove box in my car.
    The built in Pioneer AppRadio3 mirrors my box by HDMI connection to my radio. Touch control is supported by ARUnchained and works fine so far.
    The problem is, that I don´t get MP3 working without stuttering, while navigation is running.
    At least I´m looking for a Android box which can handle it as expected.
    Additional, I need a Mic input 3.5mm to not use an USB mini sound card.
    3Amp power supply is connected, a 500GB hard disk is used and for some reason an USB mouse (just to be sure if something´s going wrong with the touch control)
    Any idea what to buy to get out of the frustration about sound lags and pauses.
    I think about spending ~ 100-120 bucks for a new box.
    Help is really appreciated.
    Thanks guys,
    Peter
