help Unbrick M8s V1.1
    Can someone tell me how i can unbrick this board "http://i.imgur.com/TTA4kpv.jpg" i have try the usb burn tool but it stop in 2 seconds and i try a the sd card but notings work.
    when i power the board the blue led is only flash one time.
    do i used the wrong firmware ?
    do i need to make a connection on the board ?
    Please help me.
    Please tell me the firmware version i have to use.
      I have the same m8s version. did you find any firmware that is working?
        No i have search a lot of hours and try al lot of img but none are working
          did you try the one just me posted?
            wich one?
              sorry posted in the wrong thread but I wonder would the m8s v1.0 firmware work I posted firmware that worked on those basically everything worked great except light was red instead of blue
                Hello i have same box.I can help you. I have same problem with my box.I debricked my box by this way.
                1By using USB_burning_tool I have loaded
                cyx_m8s_v8.6_ap6330_8g2g_kodi_addons_ota_150908_US B.img
                2 by SD (even without Boot Card Maker only format to fat32)
                I have loaded: n200c (n200C-ota-20151110.zip).If you need link i give you later
                  Link Please and Than you!!!
                    hello domp3 can you send the links.
                    Thanks.
                      ok 1 link for burn https://drive.google.com/file/d/0B0k...w?pref=2&pli=1
                      2 link for sd https://yadi.sk/d/WrvdDd-kpqf63
                        Many Thanx for the Links!!!
                          hello domp3 do you have do extra thinks because i get a error when i flash the img.
                            Actually I only get to 4% I have yet to find an Image that works although domp3 the Image you posted did work for me Twice Before but not now!!! Thnax
                              its very interesting See foto and find differences https://yadi.sk/i/xMgh8_uUpwtP6 .I don't find . The first file need to flash with usb burning tool
