So I recently purchased a M8S Box (S812 2GB RAM) and I thought the box was a brilliant bit of kit, but the UI had extreme lag. So I did a little Googling and found that a lot of people said that Megatron ROM was pretty good, so I downloaded it from mega-tron.tv and attempted to flash it.
- First I put the whole .zip file into my SD card and entered recovery and selected Apply update from EXT. Didnt work.
- I realised I was meant to extract the .zip file so I did that. Copied the contents of the .zip file to my sd card and tried again through Apply update from EXT. Didnt work.
- After the flash failed I rebooted the box and then tried to enter recovery again, but I couldnt, it was stuck on the blue/green Amlogic logo for ages and doesnt boot. So then I disconnected the power and reconnected then it rebooted as normal.
- Then I tried flashing the Megatron ROM through the power and reset button method. Tried it many times, but same result, it was stuck on the blue/green Amlogic logo for ages and doesnt boot. Had to disconnect/reconnect power to get it to boot as normal.
- So I tried to flash the recovery through Rashr app. It said success but when I selected reboot into recovery, stuck on the blue/green amlogic logo
- So then I tried flashing Megatron ROM through FlashFire APK. It did the whole process, but got stuck on the blue/green Amlogic logo again.
- And, I cant factory reset the device it gets stuck on the blue/green amlogic logo
Im at a complete loss for ideas. Would really appreciate any help.
