Review of MXQ S905 from SZTOMATO
    MXQ S905
    First of all, i will say thank´s to http://sztomato.com for Sending me the MXQ Box for a Review.
    Between the extremely cheap TV Boxes with Low Power CPU, the most interesting devices are the ones equipped with Amlogic S905.
    The MXQ from Tomato is Powered by an S905 CPU with 1GB Ram and 8GB NAND.
    Also, the Box runs on Android 5.1 with good Performance.
    Here in the followings are the technical characteristics of the Box:
    Hardware Specifications
    Model No. G9C
    CPU Amlogic S905 Quad Core ARM Cortex™-A53 CPU up to 2.0 GHz (DVFS)
    GPU Penta-Core Mali-450 Up to 750Mhz+
    FLASH 8GB EMMC
    SDRAM 1GB DDR3
    Power Supply Specifications
    Power Supply DC 5V/2A
    Power Indicator (LED) Power ON:blue; Standby:Red
    Main Features
    OS Android™ 5.1 Lollipop
    3D 3D-HD 1080Px2
    Support Decoder Format HD MPEG1/2/4,H.264/H.265, HD AVC/VC-1,RM/RMVB,Xvid/DivX3/4/5/6 ,RealVideo8/9/10,HEVC MP-10
    Support Media Format Avi/Rm/Rmvb/Ts/Vob/Mkv/Mov/ISO/Wmv/Asf/Flv/Dat/Mpg/Mpeg/MP4
    Support Music Format MP3/WMA/AAC/WAV/OGG/AC3/DDP/TrueHD/DTS/DTS/HD/FLAC/APE
    Support Photo Format HD JPEG/BMP/GIF/PNG/TIFF
    USB Host 2 High Speed USB 2.0,Support U DISK And USB HDD
    Card Reader SD™/SDHC/MMC Cards
    HDD File System FAT16/FAT32/NTFS
    Support Subtitle SRT/SMI/SUB/SSA/IDX+USB
    High Difinition Video Output Support All Standard SD/HD/4K2K Ultra HD Decoding And Output
    OSD type of languages English/French/German/Spanish/Italian etc Multilateral Languages
    LAN Ethernet:1000M, Standard RJ-45 (optional IEEE 802.3 10/100/1000 Gigabit )
    Wireless Support IEEE802.11 b/g/n Bluetooth™ 4.1EDR
    Mouse/Keyboard Support Mouse And Keyboard Via USB;Support 2.4GHz Wireless Mouse And Keyboard Via 2.4GHz USB Dongle
    HDMI™ HDMI™ 2.0 (CEC and HDCP 2.2), 4K X 2K @60 fps
    AV Support
    Optical Support
    3G Support
    SPDIF/IEC958 Optical
    IPTV And OTT Support Many Kinds of IPTV And OTT Programmes
    Dimensions and Build Quality:
    The MXQ has a Size of 12 to 12 cm and 2 cm in Heigh.
    On the Top there is the MXQ Logo, it glow Blue when you turn On the Box. Cool, i like it.
    There are no gaps or sharp edges on the Housing, overall a good Build Quality.
    With the Remote that comes with the MXQ, you can control it without any Problem.
    The remote has a rounded back and fits very well in the Hand.
    Benchmark and Test:
    All benchmarks have been repeated 3 times and results have been averaged to give a more accurate reading.
    Antutu Benchmark:
    Score: 37102
    3D: 4000
    UX: 14423
    CPU: 13599
    RAM: 5080
    Overall a good performance, faster then other S905 Devices.
    A1 SD Benchmark:
    A1 SD Benchmark tests RAM and flash memory speeds.
    Internal Memory:
    Reading: 44.29MB/s
    Writing: 22.57MB/s
    RAM:
    Ram Copy 2376.85MB/s
    Both are good Values.
    Video Playback testing (Using KODI):
    Resolution Video Format Local Playback Network (Wi-Fi/LAN) Playback
    720p (1280*720) AVC ([email protected]) Work Work
    1080P (1920*1080) AVC (High@L4) Work Work
    2160P (3840*2160) HEVC (H.265) – 10Bit Work Work
    4K (4096*2304) AVC ([email protected]) Work Work
    4K TS HEVC files HEVC (H.265) Work Work
    Firmware Test:
    The Firmware on the Box is good and have so far no Bugs.
    They are using a New Launcher, it looks good.
    You can easy Navigate with the Remote that comes with the Box.
    Conclusions:
    The MXQ is a different kind of kodi machine, both for its unusual shape and its target audience.
    It gives an average performance.
    Would i recommend it?
    Yes, i would solid Device with good Price.
    Neomode
