I have to thank dwtk for their support with the video https://www.youtube.com/watch?v=t_fMCUXwF4Q
My box was bricked, only have red light, reset button wasn't have any result, USB burning Rom give me erro after 4 seconds in "...USB" with and without option seven in start options (disable controllers) . I try everything without success.
I try with the video and my MXIII M82 Amlogic S802 1GB raised. Everything it's ok, I have 65MB of download with eternet cable and before I had only 38MB.
The RAM it's only on 20%, it's very fast in android menu and aplications.
At this moment I have one problem, when activate Wifi makes the wireless network search and doesn't get out of here.
I think that this ROM isn't compatibitly with the Wireless network card.
Yesterday I try CPU Z and it say that my box have 2GB RAM It's the rom that say to software that have 1GB or my box have realy 2GB?
I try many roms to MXIII from all web (freektab, chinagadgetsreviews, XDA, etc.) but many of them it's img and my box give me the same error. Only result SD Card with files of the video.
I don't have any more ideas.
I didn't open the box so it can't indicate the model of the board installed.
Someone have any idea? Hi need to change the stock rom because in AV cable I can't have audio, the option in menu it's "locked" and I can't choose anything audio option. With this rom it's ok, only wifi didn't work.
