T11 Intel Cherry Trail Z8300 Windows 10 Mini PC 2G/32G WIFI LAN SATA Bluetooth4.0 HDMI 1080P USB3.0
    Intel Z8300, 4 core, 1.84GHz, 64bit
    GPU: Intel HD Graphics
    2GB RAM
    32GB eMMC ROM
    Support External 2.5" HDD (up to 2T)
    Authorised Windows 10
    USB 3.0 * 1 + USB 2.0 * 3
    OTG port VGA: Support 1920*1080
    Card reader: TF Card
    Support the latest HEVC (H.265) decoding
    Support 4K*2K Super HD video playback
    IEEE 802.11b/g/n, the fastest wireless internet
    Bluetooth 4.0
    Intel Z8300, 4cores, 1.84GHz, 64bit
    2GB RAM
    32GB eMMC ROM
    OTG port
    Bluetooth 4.0
    Support XBMC/KODI
    Mainstream Intel Processor
    Built-in latest 14nm Intel Z8300 processor from Intel and authorised Windows 10, integrated GPU performance increased by 40% , total power consumption decreased by 30%
    Small But Smart
    Portable and slim, NEXBOX T11 is just slightly bigger than your wallet. When being connected with a regular TV via HDMI, it will convert the latter into a Smart TV, functioning as a PC. Furthermore, it can work as a TV BOX for you to enjoy smooth multi-tasking, games or movies.
    Enjoy Your 4K Home Theater
    NEXBOX supports HD and UHD 4K (3840 x 2160 @ 60Hz) ultra-high-definition video, which in turn shifts your living room into a home theater.
    Expandable by Extra HDD
    Based on modular design, NEXBOX T11 allows for additional 2.5" HDD (up to 2T) installation for super high capacity data storage.
    Multi-display Productivity
    NEXBOX T11 supports dual independent displays without additional graphics card. The additional displays spares more onscreen space for multi-tasking; you can spread out your work windows, mirror content, or extend a single window across multiple displays.
    Save $150 Per Year On Energy
    A genuine energy vanguard; total power consumption below 30Watt in full loading , meaning that you can save at least $150 per year on energy bills.
    Save $20 On Cable
    The VGA port allows you to connect the LCD monitor via VGA port directly, so that you don't have to buy a HDMI to VGA cable(normally $20 higher in price than a simple VGA cable).
    Mountable to a Monitor
    NEXBOX T11 can be mounted to the back of the LCD monitor, which makes it completely invisible on a desk. With such a low-noise PC, people will hardly notice its existence at all.
