So here it is.
This works just like the EZ Root ZIP I made as far as installing it.
This removes all root files and permissions and takes you back to stock so OTA etc will work again (if it would not work before).
This has been tested to remove root if you used my EZ Root ZIP. I do not know if it will work if you used other rooting methods!
You have been warned!
Download the link below.
Unzip the file and put the 3 files on a SDcard.
ez-unroot.zip
recovery.img
factory_update_param.aml
Insert the SDcard into your Tronsmart S95
Unplug the power, wait 3 seconds and plug it back in.
Now this is the important part. We need to boot the recovery you put on SDcard not the internal recovery or the ezroot.zip will fail signature.
Go to "My Apps" and run "Update & Backup".
Click on "Local Update" and click on "Select". It should find ezroot.zip on your SDcard.
Select that and proceed.
The S95 will reboot and install the update and your done!
Enjoy the clean un-root
Here is the download link:
ROM -> S905 EZ Un-root (11K)
