Mini MX Software update,Firmware Version: s905_105L1
    Based versions: s905_104L1
    Updated content:
    1.Make wifi MAC address customization;
    2.Update Kodi for the official website of the Kodi 16 BETA5, to solve the problem of Kodi 4K video playback;
    3.Solve the problem of screen broken when played a part of 4k video sources;
    4.Support HLS V5 libplayer;
    5.Solve the problem of the probability occurrence of picture frame problem when continuously testing UHD video playback;
    6.Solve the problem of MXplayer stuck and progress bar abnormal when playing local video;
    7.Solve the problem of mpeg2 dash video can’t play;
    8.Solve the problem of screen stuck when playing rtspH265 video;
    9.Solve the problem of playing some of the online video is not synchronized;
    10.Solve the problem of screen black when playing some of H265 video;
    11.Solve the problem of occasionally flash full screen stripes when switching channels;
    12.Solve the problem of HDMI Passthrough play TRUE-HD audio track video silent and screen stuck;
    13.GPU optimized;
    14.Support Google Widevine L3;
    15.Solve the problem of some online video play pause after a period of time can't restore play;
    16.Solve the problem of connecting the mobile hard disk to display the total storage space is only 10M;
    17.Solve the problem of restart and serious stuck after running long time game;
    18.Solve the first broadcast truehd audio broadcast other video again hdmi passthrough silent problem;
    19.Solve the problem of WiFi transmit picture too slow;
    20.Solve the CVBS video broadcast and then switch to HDMI video down to the upper left corner but exit back to normal;
    21.Solve the problem of 4K H264 video broadcast images randomly flashing;
    22.Solve the udp streaming multicast embedded dvdsubtitle dolby sound ts stream cannot display subtitles problem;
    23.Solve the problem of unable to play HLS MP4 stream;
    24.Solve the problem of screen blackout after network adaptive video seek;
    25.Solve the problem of no subtitles when stream HLS V5 under .vtt format;
    26.Solve the probability of occurrence of a black boot that need to plug HDMI line recovery problem;
    27.Solve the problem of no output or output screen flashing after the standby wake up;
    28.Solve the switch from HDMI to CVBS restart and then cut back to HDMI output appears the problem of the white image;
    29.Solve the problem of no output after standby awakening even pull plug HDMI line;
    30.Solve the problem of stuck on the boot image;
    USB--brush machine file:
    Chained address:http://pan.baidu.com/s/1hrpTh5q password:ckcl
    Card--brush machine file:
    Chained address:http://pan.baidu.com/s/1kUkxk2b password:arqn
    Translation(OTA升级)
    1.If the network did not receive FOTA upgrade notification, can use the remote reboot, or recharging;
    2.After Pop-up notification of the upgrade, pay attention to choose to upgrade, because the default button is not in the location of the upgrade, the need to use the remote control to select or click the mouse to choose; upgrade process do not interrupt;
    3.If there is no option to upgrade, then after a period of time (3 days of a cycle) will pop up again upgrade notification;
    4.Under the condition of the Network, if manual to OTA upgrade interface (System update), prompt the Network connection failed, so is OTA server has a problem or adjustment, appear this kind of circumstance, can timely feedback.
    For more information: www.azw-online.com
    With this version with kodi work screen fps change on the fly to movie?
    Hd audio bitstreaming already work with kodi?
    DTS-HD passtrough will work?
      Can someone please rehost the firmware files? It is very difficult to download.
        SDcard firmware mirror, md5 file included to check downloaded file, you need to extract zip archive and copy contents to root of sd card:
        https://mega.nz/#F!lNUj1Q7a!Zwww2YHhFyF-zKexl1VWNg
          Thank you csgabe!
            Dear AZW,
            As you seem to be in relation with the manufacturer of this boxes, can you try to get information on the fix applied in new batches to improve wifi signal strenght, please?
            Mine is 20 feet from the router and gets a very poor signal, and it's even worse when using a paired bluetooth headset. If you can provide information on the fix, I could try to apply it on my box (I understand I'd loose the warranty), and I'll try to write a guide with pictures explaining how to apply the fix.
            Kind regards,
            David
              with this firmware no ac3 , no dts passtrough
                via SPDIF its working still. but yes i get the same results with HDMI passthrough
                  Thats really a stepback..
                    What is quite clear at the moment is that, despite the good potential of the chipset, we will wait a long time to achieve the functionality of a Raspberry Pi on this box... the passthrough issue is major for anyone owning a HomeTheatre decoder, and the lack of frequency adjustment means poor playback in most cases.
                    The box is at present acting as a dust collector on my desk, waiting for a custom firmware that can fix what at present seems unfixable....very sad.
                      When coming out new fw to fix this important issue?
                        Hopefully very soon after chinese new year..
                          I am with you, its just sitting and collecting dust for me, hopefully some capable forum member can do something positive with the software.
                            How can I reset the device? I updated it yesterday. Update went fine, but it can't boot ever since I switched off. There are no buttons to reset it, so there must be a procedure to restore it throug USB or Micro SD...
                              Underneath the box there is a little hole, unplug power cable, insert a paperclip end in there and try to catch a "click" there, keep pressed and insert power cable, when you see the bootimage, release the paperclip. You should be in recovery, with a mouse choose clear cache, wait, then choose reboot, done
