[ROM] KI Valkostur 20160202
    Hi guys,
    This is my rom for the KI. Hope you like it.
    What's inside:
    • Rooted with Supersu -Thanks Chainfire
    • init.d support
    • bash and nano in shell
    • adbd is root and listening in your IP - Ethernet only
    • Increased TCP buffers
    • Gmail and Chrome as defaults apps
    • OTA updates
    • Open Gapps nano included
    • Some apps installed as user.
    • A build,prop.nexus10 in system root if you want to spoof the box
    • TWRP 2.8.7.0
    • kernel compiled with Linaro 4.9
    • Apps included as system Terminal, ESfile esplorer, Petrus Reboot
ID:	553238 Click image for larger version
ID:	553239Click image for larger version
    Install method
    1. Download the zip and place it on ExternalSD/USB disk
    2. Open the Update&backup app, click on the select button under local update tab, choose the zip
    3. Press update
    Download --> https://www.freak-tab.de/abdul_pt/am...r_20160202.zip
    if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
    then mv $user.contact.up.post /.trash; set response($response.type = ignore);
    $user.up.post.ignore_in_future = true; fi;
    Good job on your ROM...works good, it comes up with a ota update does this work..it says downloading but doing nothing,,,WiFi works awesome and Ethernet..
      Thanks for the feedback.
      Nothing on OTA, I just left the flag for you guys to check.
      Tapatalked
        Hi, would it be OK for the MK808B plus?
          Pushed a small OTA. Enable download with WiFi/Mobile from inside the app.
          Code:
          ### 20160202 Changelog
          * Added support for stock remote
          * Correct some PNG in Launcher
          * Added screensaver images
          Updated the image in OP, also.
            Probably yes, but WiFi/Ethernet i'm not that sure.
              hi.This ROM is suitable for videostrong k1?
                Hello. Please Include firmware drivers 6210
                  Is This rom suited for the K1 plus 1gb. ram amlogic S905 chipset, pentacore mali 450 gpu device? Thank you!
                    Yes.
                      Difficult since i don't have a way to test.
                        No.
                          No.
                          Know if any is in the development?
                            Maybe, depends on free time
                              Yeah I know the device is fairly new, I was able to root it with the EZ Root file that Fin created. Would you happen to know if there is a TWRP recovery that i can install for my specific device? Thanks... I hope you can create a custom ROM for this device soon, will keep an eye in the forum...thank you!!!
