Sound problem with NX785QC8G
    4 months ago, my son's told me there was a problem with the audio. When I checked the tablet, I realize it wasn't a problem with the audio itself, instead it was a malfunction. There wasn't any audio on apps, only with headphones, so my first diagnostic was "Speaker not working". Later I was checking on the settings to see if there was an option or something I was missing that maybe caused the malfunction, and going into the "Default notification sound" and change it, IT SOUNDS ON THE SPEAKER with no problem. So I guess it's a problem with the ROM itself.
    I've already tried a factory data reset with no luck.
    I've tried a hard reset too, and there wasn't any luck neither.
    So I was thinking in flashing it with a modded ROM, but the only one I see is Shaunmt's Modified ROM, but it is for the NXM865FD board, and I have the EBM865FD.
    Is there any modified ROM I can use to try and fix the sound problem, or can you recommend me something to fix it?
