So nice firmware !!! Works fine with my MK68 from RKM but the only trouble is "Unable to reboot".
    Hello,
    Just to let you know that your firmware is really well done, i have many fonctions that do not exits on my one MK68.(Samba, Kodi...)
    The only trouble is the reboot does not work !!! (reboot system) the box does not respond, so i have to remove the power cable and put it back
    I really would appreciate, someone could tell me if i can do anything to correct this ?
    (flash img file, changing a file on the root ,...)
    PS : I red that you really made product with high quality. NEXT TIME you can be sure i will buy your product !!!
    Regards.
    Google99
