Change Cube T9 's Device ID
    This application allows you to change your Android Device's Id
    Backup the original Android Id first ,
    and also generates new ids.
    requires root access as it will modify the settings data base that contains the android id value in a system data directory.
    will not work if your device is not rooted
    Use at your own risk,
    I am not responsible if any happens to your device,
    Highly recommend doing a backup of your rom.
    New ID will generated at first next boot ,
    and should remain constant for the lifetime of the device.
    (The value may change if a factory reset is performed on the device.)
    Backup your Android_Id and restore when changing roms
    Tested on Cube T9 ,100% work
    Application will protect you if the db is not found or root access is not allowed.
    RESTART OF THE DEVICE IS NEEDED FOR CHANGES TO TAKE EFFECT
    https://drive.google.com/open?id=0B4...mV1MEdIbzhpZVE
    thanks for sharing
