Thanks to Ugoos for supplying the UT3+ and lightning-fast shipping via DHL.
Some Specs:
- Rockchip RK3288 Quad-Core CPU
- 2GB RAM
- 16GB Storage
- Dual-Band AC WiFi
- 10/100/1000 LAN
- 3 USB 2.0
- uSD card slot
- SPDIF
- HDMI In(ver.1.4 up to 1080px60fps) via a Toshiba 358749XBG converter chip. Note: HDMI In will not accept HDCP source, ie. DVD player, Cable STB, etc.
- A/V Out Note: This jack is different than the jack on the UT3. From the looks of it, it only handles audio. The jack is about 3mm shorter and has fewer contacts than the UT3 jack. This means no analog video on the UT3+.
- External Antenna
- Alloy Case with ventilation on the bottom and side(Antenna/power button side)
- Fan
- RTC Battery
Unboxing pics....
More to come....
