Any How To's on where to get started with this hopefully i can release to you all once done.
Debloat ROM How To ??
i am looking to try and make this as close to Android TV Experience as i can, removing all the Apps i do not want and adding in the ones i do all while doing this via a ROM an dnot having to install root and remove apps each time i may reset the box.
Any How To's on where to get started with this hopefully i can release to you all once done.Tags: None
The easiest way without having to learn to make a ROM is
Root the device
Using ES file explorer go in and do the following:
1) Remove APPs from /system/preinstall
2) Remove APPs form /system/app
3) Remove APPs from /system/app-priv
Now when you reset none of these will be there every again.
Well unless you flash another ROM.
Originally posted by Finless View PostThe easiest way without having to learn to make a ROM is
Root the device
There are currently 2373 users online. 0 members and 2373 guests.
