S905 Navigation Bar(Soft Keys) and Status Bar enable?
Any one Figure out how to enable the navigation and status bar on s905 roms.....i think they are all have them disabled in the SDK. Tried build.prop method and it doesn't work. no notifications and not able to close apps out sucks. I can close out apps with alt tab but i have to hold alt and swipe off screen. Might have to modify systemui.apk etcPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****Tags: None
If I remember correctly, the Xposed module GravityBox[LP], has some settings for the bars. Maybe it will work for you.
It has a bunch of cool customizations and tweaks. GravityBox added many functions to my stock remote.
There are currently 2672 users online. 1 members and 2671 guests.
