TWRP 3.0.0 Has Been Released
    TWRP 3.0.0 has now been released for all devices that are currently supported and comes packed full of new features and a completely new look.
    The TWRP team has also issued a warning that as this release brings some significant changes it is possible that some devices may not boot correctly or have display issues due to the graphical changes. It is highly recommended that you ensure that you are able to flash an older version of TWRP in case of these errors.
    changes included in version 3.0.0 are:
    True Terminal Emulator – Includes arrow keys, tab and tab completion, etc. (by _that)
    Language translation – Languages that require large font files like Chinese & Japanese won’t be available on most devices. Some languages may only be partially translated at this time. Translations are welcome over at OmniROM’s Gerrit. (mostly by Dees_Troy)
    Flashing of sparse images – On select devices you will be able to flash some parts of factory images via the TWRP GUI (by HashBang173)
    Adopted storage support for select devices – TWRP can now decrypt adopted storage partitions from Marshmallow
    Reworked graphics to bring us more up to date with AOSP – includes support for adf and drm graphics (by Dees_Troy)
    SuperSU prompt will no longer display if a Marshmallow ROM is installed
    Update exfat, exfat fuse, dosfstools (by mdmower)
    Update AOSP base to 6.0
    Many, many minor fixes and tweaks
    Thank you for this
    Team UX
    http://www.ultimatexbmc.com/
    http://www.freaktab.com/showthread.p...-ULTIMATE-XBMC
      Can this be used to root the Cube T9 (v1.08) I only need to root so I can load more apps. I'm not iterested in flashing a new OS.
      Also, will this new viersion work with Windows 10 and USB 3.
      Cube T9 - Build v1.08 - OS v4.4.4 KitKat - Rooted.
      LG G4 - OS v6.0 Marshmallow.
      Dell Inspiron 15R SE 7520 i5 - Windows 10
