Firmware & OC Kernels for RK3066 XT-E809-V10 MK809II RTL8723BS
    Find below the following firmware and kernels for the MK809II / XT-E809-V10 RTL8723BS RK3066 tv stick.
    All firmware and kernels are Kit Kat 4.4
    Найти ниже следующей прошивке и ядер для TV Stick MK809II / XT - E809 - V10 RTL8723BS RK3066 .
    Nayti nizhe sleduyushchey proshivke i yader dlya TV Stick MK809II / XT - E809 - V10 RTL8723BS RK3066 .
    1080 разогнанных 720p разогнанных
    1080 razognannykh 720p razognannykh
    1080p OVERCLOCKED - click to download 1080p firmware for XT-E809-V10/MK809II | CPU1608 | GPU400 | DDR600
    720p OVERCLOCKED - click to download 720p firmware for XT-E809-V10/MK809II | CPU1608 | GPU400 | DDR600
    Kernel files - 1080p | 720p
    Find below the following firmware and kernels for the MK809II / XT-E809-V10 RTL8723BS RK3066 tv stick. 1080p OVERCLOCKED - click to download 1080p firmware
    Hello!! Appreciate your valuable effort to make things simpler for us all! :-)
    I have a question.. I downloaded the 1080 & 720p firmwares, but I don't see one single image file, there is "boot, kernel, misc, recovery, system".
    I can't use them with RKBatchTool.
    What am I doing wrong??
      ... did you figure it out? If not, download the RK Android tool - http://www.mediafire.com/?b6i53a9j94a96en
      ... tick the boxes for the corresponding images you'd like to flash, click the file path for each image and you're set to flash.
      You can flash all at once, or try the kernel only, system, etc.
        Hello, thanks for your topic. But I have this tv stick and I tried to load several firmwares and none I can run completely. Could you make this img firmware available for upgrade even though it is an older version? Please thank you
          Ol?, obrigado pelo seu t?pico. Mas eu tenho este tv stick e tentei carregar diversos firmwares e nenhum eu conseguo rodar completamente.
          Voc? poderia disponibilizar este firmware img para upgrade, mesmo sendo uma vers?o antiga?
          Por favor, Te agrade?o
          Desculpe o meu ingles.
            compatible au mk806 q
