I just spend several hours trying to unbrick my good old MXIII 1 GB Beelink player. I tryed to do upgrade from android directly (OTA, select file....) but something went wrong and flashing just stopped. Then I turn it off and on again but this time only blue light appears on device itself but nothing on tv screen.
So I decided to perfom SD card recovery and USB burning tool recovey but without luck. Computer does not wanna detect MXIII (i use different otg cables, different computers) i preses and depressed reset button behind AV slot milion times just nothing. Also I tryed recovery with SD card method, different formats, different firmwares just nothing. Is there anything else I can try to do.
Device is:
MXIII s802 1gb with realtek wifi
M82_v2.0
Netxeon
I use this file for recovery M82_108k4_sdcard.zip (extracted on fat32 formated card). I folowed all to me known instructions but no luck.
So now only blue light glows and TV detects that something is connected on hdmi port, what else I can do ?
Thank you in advance
