Image washed
    Image washed
    Hello,
    On android I have a problem that I do not understand and resolve the least:
    On one of my TV (KDL-40EX600 SONY) when I plug in a box CX919 Android 4.4.2 on a HDMI port, it works without any problems.
    If I plug Tronsmart META or TELOS (I have both) on the same HDMI port on the TV, after a few minutes the picture is completely washed out or too saturated.
    I made all the settings that I know but nothing changes. (Cable change, lower the resolution, change the TV HDMI port, change the HDMI settings of the TV .....)
    I deduced that the HDMI output Tronsmart is too "powerful" and the HDMI port on the TV has trouble digesting it.
    Does anyone have any idea to solve this problem?
    Thank you
    For information: both Telos and Metal Machines are root. I installed on both machines the Rom Finless
    Have you tried different frequencies 60 vs 50 ?
      Yes, i have tried all resolution including 50 and 60 frequencies and nothing work
