Upgrade decision
Upgrade decision
So, I currently have a set top box that I built out of a UG802, powered usb hub, and a few adapters. It works very well, but I made sure that I designed it so that should I ever want to upgrade it is easy to swap out the UG802 with any other stick I want. Now that there are a few options available with the RK3188, and now that there is progress being made with the video frame-rate issues, do you guys think it would be worth it to buy a new stick? The CX-919 is available for under $80 and I think it would be my choice. -
Honestly I would wait a while, although the bugs maybe being ironed I'm my opinion the hardware has design floors, check out bobs video here
Ive had the mk808 (3066) and then the mk908 (3188) the 3188 chip just gets too hot and needs some better cooling than whats currently provided inside those small cases, If its just 720p or non intensive tasks you may get away with it but unfortunately if you drive it a little too hard or even 1080p then it can easily overheat. ( I can confirm that through testing )
There are currently 4620 users online. 0 members and 4620 guests.
