Beelink i68 firmware WiFi and Bluetooth fix for AP6330 chipset
Originally posted by tsukaza View Post
Open the box and check the WiFi chip for AP6330 or AP6335. Google the picture for i68 internal. If the Zidoo firmware does not turn on the WiFi and Bluetooth you likely have the AP6330 chip.
open means real open..?with screwdriver or like that..? isnt there any other simple way..?
Originally posted by pithboss1972 View Postokay got wifi to work but only see 2.4 Ghz before was 5.0 was also available anyone else
The fix only allows 2.4 Ghz to work, to get 5.0 Ghz you need to use firmware make for the Beelink i68. This is as good as we can get for now. Maybe somebody with more Android driver knowledge can find a fix.
There are currently 2352 users online. 0 members and 2352 guests.
