MXIII-G and PS3 Controller
Hi,What FW are you running & what version of sixaxis are you using..
Have you tried sixaxis 0.8.3Please consider making a Donation to freakTab
Oh you are running the lollipop rom..I think you will need to uninstall the updates to google play services & google play store, reboot & sixaxis should work
You can change the curser to what ever you want but its a little complicated you will need to edit the curser image in the framework-res.apk found in system/frameworkPlease consider making a Donation to freakTab
There is some firmware listed in this post here http://freaktab.com/forum/tv-player-...320#post542320
The 316k4 KitKat firmware is not bad
Its also well worth reading all the 45 pages of my review over at xda theres some good info from other users there,it was all on here but it got deleted after a tidy upPlease consider making a Donation to freakTab
There are currently 2156 users online. 0 members and 2156 guests.
