a friend bought a cheap RK3188 Box that was described as Q7 with 2GB RAM and 32GB ROM (!).
After it arrived the box was horrible and he gave it to me to flash the latest "Q7" firmware.
So as far as I know there are no Q7 with 32GB which made me suspicious so I opened that thing up and saw this:
[ATTACH=CONFIG]n555314[/ATTACH] [ATTACH=CONFIG]n555313[/ATTACH] [ATTACH=CONFIG]n555315[/ATTACH]
So first thing RK3188 is false its a crappy RK3128. RAM/ROM unknown (at this point). PCB Says G_918 V 1.2
In Android (4.4) System it shows 32GB ROM. Antutu 6 gives that thing ~15000 Points. After checking around the RAM seems to be correctly 2GB but the ROM is (according to android Tool) only 16GB.
So far so good or so bad.
First I dumped the original firmware:
Original Firmware Dump dated 20151110:
Then I searched around and only found mentions of this crap Board/Model on the Russian 4pda Forum. I also found a working firmware in this:
G918 XGoDY Firmware 20151106: https://mega.nz/#!s8AXTA5B!5bmuKb7V_...60G55_o58ls3TA
With that firmware it shows correctly that the box has only 16GB ROM. Other than the boot logo and the slightly newer firmware on my box they have the same apps ect. installed.
Seems XGo DY orders this crap from the crap factory and loads their stuff on them and sell that junk on **** and Amazon claiming its the best thing ever and with "Kodi Fully Loaded". Despite this not beeing legal in so many ways its just sad that they can get trough with this crap (They also sell "fully loaded" Navigation Systems ect.).
Anyways so I told my friend that he bought a crappy and fake box i tried to root that thing.
And here comes the pain: I don't know why but there seems no way to edit the ROM Parts (I tried every tool here....just shows invalid img). I tried every (EVERY) Root Prog and App and the only thing working is some shady Root Zhushou that installs KingUser Root. While i can a normal SU on that device, the update of the SU Binaries fail.
Maybe someone could help me out here...and/or have a look at the rom....why the heck it can't be edited rooted ect.
Thanks and greetings.
