Wifi drivers
    Wifi drivers
    Hi all having a bit of a mare with one of my mxq box's i managed to brick it when trying to instal openelec but have managed to get it going again using the usb burning tool and shorting the pins out on the nand.
    Only problem i have is the wifi wont work and reading around it seems to be a common experience for many people
    I have another working box that is the same can i somehow extract the wifi firmware files from it to add to the other box?
    The wifi chip is the following as it hasn't come out in the picture
    RTL8188ETV
    F61AK32
    GF39
    Try Overwritting with original Dho.ko + wifi folder. But i think is not compatible with openelec,only with other android rom. I've tested it for porting cm11 to ap6212 devices. Good luck
