Kodi 15.2 (Final) for Rockchip 3368 (bitream first test ok)
Can someone tell me how kodi determines the screen info?
On spmc 16+ the "sync playback to display" option works, but unfortunately for me it syncs to 30fps instead of the 60 my tv is at. When I open system info it incorrectly states my screen resolution as [email protected]. Pretty much every version of kodi I have tried gives me the same wrong info, except for the versions in this thread.
When I open system info on the version I got from this thread it correctly states my screen resolution is [email protected]. Would it be difficult to apply this proper screen reading to a different version of kodi? Or would it be possible to make "sync playback to display" work in the version listed above? (I posted this question in the kodi forum as well as the spmc. If I find a resolution I'll post it to all 3 boards) I have an ekb368 (or Z4) which also uses rk3368 on android 5.1.1
In case anyone was wondering it is in: EGLNativeTypeAndroid.cpp got the info from http://forum.kodi.tv/showthread.php?tid=237315
Originally posted by Yorgosphere View PostCan someone tell me how kodi determines the screen info?
SPMC doesn't have the correct refresh rate settings for Rockchip devices yet.
Rockchip will probably change something in their firmware for SPMC to work correctly or make a small adjustment to SPMC for it to work correctly.
They are doing tests now with SPMC.
But your problem will still not be solved as EKB368 devices have very bad firmware support and the manufacturer might take several months before implementing this new code.
Always buy from manufacturers with constant firmware updates in the future to not have such problems.
Yeah from what I found the display settings in the firmware should be located at sys/class/display/display0.HDMI/mode but on my device are instead located at sys/class/display/HDMI/mode
I also have a thread open on the spmc board waiting to hear back https://github.com/koying/SPMC/issues/180
Originally posted by aeolous View Postjust test it on my Geekbox and along with the Geekbox kodi that came with the rom and both in view mode lacks the settings to change mode to normal,zoom,display 16:9 etc.
why is that happening i also asked Geekbox forum and they will look in to that.
Also most of that aspect ratio options has been moved to Kodi Settings.
Originally posted by aeolous View PostThanks for the info mo123 you 've been very helpfull one think though if i change the option to softeare decoding will i loose from processing power i mean glitches in playbak?
Some 1080p high quality videos might not work and 4K videos won't be playable with Software Decoding.
There are currently 2240 users online. 1 members and 2239 guests.
