MX 111. Wifi issues
MX 111. Wifi issues
Hope someone can help. Have MX111 2gb and wifi has suddenly slowed down only getting 3mb of speed. It's not the router. If I have done a root explorer and deleted wpa_supplicant.config file and restart box. It brings the speeds up to about 10 or 13 Mbps but after a while it goes back to being slow again. Any ideas how to resolve this problem or is there a way to disable wifi card and use a wifi dongle. I have another mx111 1gb and the speeds are fine on this. So appears to be a problem with wifi card! Any advice would be great. Thank you.Tags: None
There are currently 3184 users online. 4 members and 3180 guests.
