I bought an MXQ from Amazon (Canada)
I was having WiFi issues, lag etc. and decided to flash the firmware. As you can probably guess it was not the correct FW for my specific board (wow, there is a lot of boards for this device) so I bricked it and am now stuck at red light only.
Not able to enter recovery mode or get any response from unit other than a constant red light when powered up.
Windows/burning tool will not recognize the device. It's worth mentioning that I only have a mac so I am running WinXP Pro SP3 in a VM in order to use the program but that shouldn't cause any issues because it is configured to automatically pass any usb devices directly to the virtual machine when it has focus (tested with countless other USB devices with no issues). I have 2 versions of Amlogic USB_Burning tool installed, 2.0.2 & 2.0.4.3
I've tried every combination of holding the reset button/powering the device/connecting to OTG usb port possible several times with no success. From what I've read I've come to the conclusion that it is going to be necessary for me to short pins on my board in order to get Windows to recognize the device. The problem that I'm having is that I do not know which pins to short and I have not been able to find a single image or version number that matches the specific board in my box.
Here is some info I can provide about this board:
IMG: http://i.imgur.com/6i3q0PP.jpg
Model: MXQ-S805_D08
Ver: 1.0
Date: 151221
nand
SKhynix
H27UCG8T2ETR
Any info or tips you can provide to get this box unbricked would be greatly appreciated. I have a rom that I believe will work for me to get back into recovery mode but if you have one you know will work for this device please let me know!
Thanks for the read
-Paul
