changing wifi module in img.
Originally posted by poul50 View Postany one with skills to compile a firmware img with new wifi driver i need this https://cloud.mail.ru/public/7oSn/WunL7sMWW firmware image to have rtl 8189 wifi driver
-if img file compression is for stock kitkat amlogic use amlogic customization tool for windows
-if img file compression is used in a lollipop rom: look on xda, there are several tools also for windows
extract original Dho.ko + wifi folder and ovewrite it in the new rom. Probably you can simply extract these file from stock rom and then copy/paste in the new rom with an explorer manager like es file explorer(market)
Originally posted by poul50 View Postit is for stock android 4.42 amlogic s805.....have tried copy past...no luck,, for customization can not get iit to Work have installed jdk but cant use it
There should be some documentation in the install to setup java environment. Java 1.7 is required I believe. I did a simple test and was successful porting over one manufacturers rom to another with the customization with the exception of storage...I didn't go much further but will return to it later after I finish what I am working on now.
Just to be clear everything seemed to work except /dataPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 1978 users online. 0 members and 1978 guests.
