Yes I have the same problem. It works once then hangs on " launching apps...." nothing happens
CS928/CS918II Lollipop stock rom - 2015-10-19
Originally posted by bach0405 View Post
Thanks,
I will try it this week end
Edit
Well, It went wrong. I am stuck :
E: failed to mount /mnt/external_sd (No such device) : 3 times
E:Failed to mount /metadata /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata (Invalid Argument)
i used Android Tool v2.3 to flash the firmware.
If someone can help me ... I would appreciate it
Originally posted by m4f1050 View PostHow can I flash this .img file? What tool do I use?
for this u use the RKBatchTool (one .img File) or AndroidTool 2.35 (for both) on first Tab ,
u use splitted Roms , on second Tab u use the full ,img Roms .
Here a Flashing Help :
http://ugoos.net/blog/rockchip-firmw...flashing-guide
good luck / report
gefattern
Hi m4f1050 ,
good luck / report
gefattern
Thanks!
Originally posted by dotdotdotz View PostTested to work perfectly on CS928,
Everything works and is super responsive! But userdata partition is restricted to ~1GB.
Tried to edit the parameter flie but still reformats the partition layout on first boot. Any ideas on how to change this?
http://pan.baidu.com/share/link?shar...dapt=pc&fr=ftw
Uploading a copy to mediafire
And, probably more importantly, does it work?
TIAThe Case for Reform
Drug Science Prof D. Nutt
The life of a good person means more to me than that of a bad person.
I have no borders as far as good people go.
Thanks.
And it works ok? No wifi issues all working well??The Case for Reform
Not connecting to v1.8 Rockchip Batch Tool.
Tried all the suggested steps. Any pointers please?
Also, the boot tool says FW Ver 4.4.2.The Case for Reform
Got the right FW now and tried Rockchip Batch Tool v1.7 as was not getting any joy with v1.8.
Same issue. I am trying to connect via the USB on the back of box, not the smaller USB OTG socket and am trying to put in power and USB at same time while holding down the reset button.
Would this work if I get another pair of hands to assist?Last edited by KBL; 21 April 2018, 12:28.The Case for Reform
Thanks,
Edit
Using OTG cable now and still won't connect.Last edited by KBL; 25 April 2018, 11:46.The Case for Reform
There are currently 2687 users online. 0 members and 2687 guests.
