NEw Tablet Suggestions?
    I currently have a Cube T9 Tablet, previous was a pipo
    However the screen is cracked so I'm looking for a new one
    Im looking for something that has the highest PPI screen and that's around 9"
    It will only be used for watching films and for flying a drone (DJI Phantom 3 pro)
    Because it will be used outside it will need to have a bright screen and as I say , the higher the resolution the better.
    What is out that to help me out?
    What CHARGER do you suggest for Cube and other tabs in general? 1A 2A 3A higher.... ? mine takes long time to charge. However, a more powerful charger should not reduce battery life and affect components!
      Replace the screen ! See my guide , after a pipo m9 pro ,a pipo p1 ,cube t9 ,teclast p98 a8h6;,cube t8ultimate, I Can tell the t9 is the best among these also for quality of camera but overall for size,screen battery connection etc the only defect is memory partition but on the freak tab thread you Can solve it . Now I have the cube t98 rom see the modding treahd.and it works perfectly
        For adb user ,I use a 9v transformer of pipo p1 with changed cable to usb connector to quick charge it .after One year every day charged no battery problem. Cube its self advertising at the production launch this opportunity
