M8 Pro RK3368 Octa Core 4K TV Box Android 5.1 2G/8G 2.4G/5G Dual Band WIFI Gigabit LAN BT4.0 HDMI2.0 DOLBY TrueHD DTS
    Old Shape never dies New innards again.
    Google Android 5.1
    Rockchip R3368 Octa Core up to 1.5GHz (Cortex-A53 64bit)
    PowerVR SGX6110 GPU
    DDR3 2G
    Onboard eMMC Flash 8GB
    2K*4K Support
    3G Support
    DOLBY TrueHD and DTS HD Bypass through HDMI
    Cheers
    Hope this box doesn't become popular as it will confuse a lot of Rockchip & AMLogic users trying to flash a different manufacturer's firmware onto their box.
      This shape just will not die, and will be very confusing for sure.
      Cheers
        Hello im search a firmware for this box is it possible to help me please ?
        Thank you
          As above..looking firmware for reinstall.please.
            Hi There,The firmware for the M8s Pro can be found in my Review Here http://freaktab.com/forum/main-categ...-tv-box-review
              the firmware in the link is for the M8S Pro not the M8 Pro. The update failed when I tried to install using the SD method.
              thanks for providing it though. Does anyone know where I can get the firmware for the M8 Pro AM53, or how I can install TWRP recovery.
                Later we will have the firmware.
                  Hi guys, any luck on the M8pro firmware? This machine is a nightmare to source software for
                    M8 PRO RK3368 OCTA CORE 4K TV BOX FIRMWARE 20160520
                    New firmware
                    blog.geekbuying
                      The firmware at the above link won't install on my box. I have the very same one the M8 Pro RK3368 Octa Core 4K. Anyone know of another source for firmware updates for this box. The Google Play Store force closes and the wifi and ethernet are horrible.
                      thanks
                        thanks
                        I can't seem to install anything on this box. Tried TWRP recovery for the rk3368 64 bit. Tried firmware updates using the sd card method etc. I can't even get a custom recovery on it. Tried CWM and TWRP. The stock rom is terrible. Google Play Force Closes, wifi end Ethernet are really slow compared to my isp speed. I like the box but it has too many issues on the current 5.1.1. Problem is most of the firmware I've found is older than what is currently on there. Is there anyone else who has this specific box that has been able to get a custom recovery or a different firmware? Would love some help
                          thanks
                          Try the Marshmellow firmware in geekbox thread 😁
                            Why have you tried it? If so do you have the M8 Pro. I would rather not brick this box especially without a custom recovery with a backup.
                              Hard to brick device. Just make sure you have orginal firmware. Yes ive used on different boxes he has different wifi chipset kernels as well if you know what onevis in your box. If not try one if everything works great if not try the other kernel resource file. 😁
