Charger and Battery life
What CHARGER do you suggest for tabs and phones in general? 1A 2A 3A higher.... ? I have Cube tablet and it takes long time to charge. However, a more powerful charger should not reduce battery life and affect components! Any effect on the processing speed, screen or its ROM ? Any suggestions?
Tags: None
Erm the same question 4 times now in the past 5 min you must be in a hurry.. Can you please not spam us with the same question. once would of been fine
2/3A will be fine. More amps will not hurt your device but more volts will kill it so be carefullPlease consider making a Donation to freakTab
There are currently 3302 users online. 2 members and 3300 guests.
