MXQ Plus (original) s905 1GB/8GB
    Since my tv box was dead, I tried to install with USB Amlogic burning tool, a stock rom .img the T95. It works well in all its app but only in Ethernet mode, the remote control does not respond. So my request is there a way to activate the WIFI although in the / system / lib and there 8189es.ko 8188eu.ko?
    And for the remote control are the codes for that of MXQ Plus to be adapted to T95?
    I had requested the STOCK ROM plus but I can not in any way to retrieve it.
    Or if someone has managed to make a din adaptation of a type rom
    MXQ_PRO_4K_rtl8189_hugsun_mod_r1, but it does not work, not even the remote control
    I would be glad to know where to download it.
    thank you very much to those who will pay attention to me.
    Sorry for my English translated by google
    Ho inserito il firmware del K1 plus and work fine.... But now screen Home of box tv when work tell " K1 Plus"... How modify
    This question?
