Vido (Yuandao) N90 FHD RK3188 RileyROM 1.1
    This is a ROM for the Vido (Yuandao) N90 FHD RK3188 tablet. It is based on the official Vido firmware released on 5/9/13. The previous ROM had wifi issues, so hopefully that was fixed in this ROM
    This ROM is for the 3188 version. If you flash it to a 3066 version you WILL brick your tablet.
    This ROM is rooted with Google Play Store fixes and 2gb user app space with init.d support.
    You now have a choice of whether to have 2, 4, 6, or 8 gb user app space. In the RileyROM folder select the parameter file you wish to use. The default parameter file is 2 gb. If you want one of the other's, just rename parameter...parameter2, then rename the selected file parameter, then flash.
    Here is the link to the download:
    Download
    If this is the first time you are flashing one of our ROM's, you may encounter some challenges in installing Windows drivers. Please download this First Time User Guide to help you throught he process:
    Download
    Thanks to Tattman65 for providing the fantastic boot graphics
    Thanks to Petrus for his Reboot app
    Thanks to the entire Freaktab Team for the support.
    Randy
    is this the 4.2.2 version?
      Yes...it is 4.2.2
      Sent from my M8 pro using Tapatalk HD
      Randy
        i have manage to flaah the rom. The wifi is working fine. But unfortunately, the rom is still 4.1.1
          OK, there is a new firmware dated 6/27...downloading now. I will try to put together a new ROM tomorrow. Stay tuned...it IS 4.2.2.
          Randy
